I acquired this 1782 from a guy, that I buy my Welding gas from, a few years ago. It had sat a few years and he couldn't get it to start, which led to him butchering the original wiring harness. I bought it for $500, sure it would be a simple job to get running. It ended up being the rack in the pump was stuck in the off position. After I got t that moving, it was down to fixing the broken trans mounts (Xtreme motorsports kit), fabricating a new electrical system from scratch and fixing the holes and bad bearings in the Haban deck. After a couple years of mowing the D640 was developing a lot of blowby, so I decided that I would rebuild a D902-e2b core I had in the shop from a Kx40 excavator I had replaced for a customer a few years back. Went ahead and modified the pump, lightly ported and cleaned the ports in the head, modified an exhaust manifold, and installed a Garrett Turbo. Fitment was pretty straight forward as far as swaps go. The engine runs strong, starts instantly with no glow cycle time, and makes about 10psi of boost where the yard starts becoming a field. Since I was shortening the driveshaft anyway for the new engine, I went ahead and modified the trans end to use a yoke that collapses after removing a pin. Turned that job into a 10 min affair.
More pics of rebuilding core D902
More pics of engine
Sweet setup, I'd like to see more of the drive shaft since the parts are becoming hard to come by now.
Thanks, I'll take some more when I get home. I basically just cut the splined section off the shaft, cut the cv plate end of the adaptor off, drilled a 5/16 hole from the end of cut shaft through it, centered it on the adaptor and welded it on. I milled a slot for the keyway on end of shaft and drilled a perpendicular hole through for the yoke. I then turned the threads off leaving only the last 5 or 6 at the head of bolt on a lathe. That way I could use it as the pin to locate yoke on the shaft.
Nice setup! have you done anything with the cooling system? it was marginal in the deep south with the D640 at full tilt mowing..
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
