Anyone on here know the weight rating for the IH cub rear ends? (Cast iron housing with aluminum axle tubes). I've been looking around for a while and I can't really find any maximum weight capacity ratings. I know Ford's LGTs were at 1500# and John Deere 318s had a 1200# capacity, but I've never seen a rating for the Cubs.
1982 IH 782 w/ custom diesel and cat 0 hitch (Soon to be mine-) 1973 Cub 128 42 inch snow blade 46GT mower deck Brinly sleeve hitch box blade |
In terms of using a rear lift, etc?
Maybe as a house designed part IH didn't publish this like the purchased parts used in competitor's units.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Yes, as in using a rear lift or ballast. There is a good chance that they didnt rate the axles.
Tags |
rear axle, rear-end |
