A buddy just found a 190-451 blower for his 1861, has all mounted but says when it’s down he can’t steer it.
Thoughts? Gonna go look at it but thought I’d throw it out there Thanks |
It's a heavy blower, and a not so heavy machine.
No more cubs. But never fear there will be more ![]() ![]() ![]() ![]() |
![]() Quote:
the front tires are hitting the blower when turned? the front tires are sliding on the snow? the front end is so heavy he can't turn the steering wheel? the blower is lifting the front wheels off the ground? ???? |
Front tires are sliding
How about some pictures??
Pic of machine
A couple of pictures
Try adjusting the lift rod connected to the blower to limit the down travel when the hydro lever is pushed down. Be sure your front tires are inflated to support the weight of the blower as well.
The ballast bucket may be contributing to the front tires lifting. Wheel weights in the rear wheels only might help solve the problem. ![]() |
Pickup the blower some, you'll have plenty of weight on the front end then. I didn't have a problem with the 450 blower on my 1811 last year (turf tires) [picture featured on the forum this month, thanks Roland].
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
