Old 12-18-2022, 03:24 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Thumbs up My eighth. 1982 1282
So, here it is. An early build 1982 1282. Nice low back seat, International dash and earlier hour counter. Cast iron rear but plain steering wheel center cap. Runs and operates very well. Does need paint and other minor repairs. Bought it 1.5 hours south of me. So, I now have 4 red machines and 4 beige/yellow machines. I am now officially out of indoor storage.
Old 12-19-2022, 10:06 AM
CubDieselFan's Avatar
That is a nice one. You need a bigger building.
Old 12-19-2022, 12:43 PM
hugo454's Avatar
hugo454 hugo454 is offline
Surely my wife can't get on me about owning 2 now,Thanks
Old 12-19-2022, 09:38 PM
Sergeant's Avatar
Sergeant Sergeant is offline
With 2 Machines, they usually don't want to Kill You! When You have 18. Don't even mention another Machine. You Just Buy it and Hope she Can't remember what the count is.
Good Thing I have some off site storage
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force
Old 12-25-2022, 04:28 PM
1711Cub's Avatar
Wink
The steering column wiggled a bit, and was ultra annoying. This tractor used the IH designed column support bracket. I retrofitted to the later CCC engineered clamp style column support bracket from an 1810:
Obviously, the clamp style is a lot more substantial, and supports the steering column.
Also, I'm replacing the steering wheel due to several chemical stains. While the wheel is off, a new MTD upper column seal was installed after the upper column bushing was greased.
lso replaced at this time was the original maintenance minder, which I have never cared for at all. I had a nice proper later CCC hour meter on the shelf. Also, the rubber ring around the column was replaced with a nice original. More to come...
Old 12-25-2022, 08:11 PM
Farmall450's Avatar
I can't stand the low seats, but they are good for cracking your back on.
Enjoy, my first CC was a 1282.
