Go Back   Only Cub Cadets > Resources > Cub Cadet Parts Sources > Parts Cross Reference
Old 10-12-2022, 01:03 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb Reverse/seat relays
While searching for parts for my 1986 1210, I found out that the 5 terminal seat relay and reverse relays were sourced from GM, as it is an A/C blower/wiper/headlight relay depending on year/make/model. While this part 725-0895/925-0895 is still available through MTD Cub Cadet, the price is a staggering $66, and probably sourced from China or Mexico. I have found several NOS USA made relays for a third of that. Here are some of the interchange part numbers:
Standard RY-12, Delco 1115826, Delco 1115858, Delco 15-8169, Delco 19106614, Duralast 19812, 1R1219, Gold Seal 2-DR1009, 2073828, 2226969, 2N2915, Four Seasons 35767, GM 3989214, Wells 56-1684, GM 89057568, Echlin AR109, AR109SB, Kem AR159, Delco D1724C, DR1009, Santech MT0511, BWD R365, RAC1274, JD191K13
Now, the later 4 terminal reverse relay 725-0894/925-0894 are now listed as NLA through MTD Cub Cadet. Again, this was a GM sourced A/C blower relay. Here are some interchange numbers:
Standard RY-11, Echlin AR108, GM 2072624, Delco D1751, Kem AR161, Four Seasons 35765, BWD R367, Wells 56-1683, Duralast 19811, Santech MT0512, JD191K16
Old 10-12-2022, 01:22 PM
Relays have three specifications. (A) Contact rating [ie: 20A], (B) Coil voltage [ie: 12V], and (C) Switch configuration [ie: SPST].
The 725-0895 is a 12V, 30A, SPDT Relay.
The Bosch #0 332 209 150 (among others) is a 12V, 30A, SPDT Relay for about $10.00.
Not a hard decision for me.
Old 10-12-2022, 03:19 PM
1711Cub's Avatar
Question
That's a good alternative. Is this relay plug and play?
Old 10-12-2022, 04:35 PM
As long as you follow the wiring instructions.
Old 10-12-2022, 09:19 PM
Farmall450's Avatar
Good stuff if I cared for a seat or reverse switch
Old 10-13-2022, 09:18 AM
1711Cub's Avatar
Talking
I get it. The reverse blade shut off is a total PITA, and adds more wear to the PTO clutch.
I do make sure the seat safety safety system works, in the unlikely/unfortunate event I'm thrown or fall off the tractor.
Back to the relays, I have located Standard brand direct fit units for around $10. Packaging did not state country of origin.
Old 10-14-2022, 04:45 PM
Farmall450's Avatar
On the odd chance I tip, I think my leg/foot would hit the ground first and push back upright. I agree if you're going sideways on steep hills (e.g. mowing - which I only occasionally do with 1 of my Cubs) it wouldn't be a bad idea.
Reverse is an OSHA scam Cub defeated w/ the reverse/caution switch.
Old 10-14-2022, 08:08 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default Reverse PYO Switch
I have a recently purchased 1862. When you go to reverse it shuts off the PTO.
Too much wear on the PTO and switch. How can I make it not do this??? Thanks and have a great day.
Bob
