I found this image on the web, do I need this piece to attach the lift bar on my 782 to the rockshaft? Where can I get one? And finally, is there a copy of the 3 pt installation manual for an 82 series?
Thanks.
2005 CC GT2544 1980 IH CC 782 1957 Cub Lo-Boy 1993 Craftsman LT4000 |
I think it probably uses a clevis pin; that's how the sleeve hitch is ran on the later tractors as well.
I originally thought I'd have to add a lift block for the 1811 or 782, but IH improved the design s.t. only a clevis pin is needed and it is inserted through a clearance hole in the frame.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
I dont see that pin in the parts breakdown. the pin that attaches to the lift arm has three holes in it.
the attached image shows the parts for the 3pt from cub. |
Looks like a float lockout pin.
This is where it's shown as being used. 82 series is different than other WF's which is why I'm looking for specific info. Supposedly the pin that normally connects the rockshaft to the hydraulic cylinder inserts from the frame side but from what I'm surmising the head of that pin would interfere with the lifting bar so the piece shown above replaces that cylinder pin by moving it to the inside thereby eliminating the interference issue. All this is a theory I've put together based on very sparse info available on the Internet so I'm hoping to find something concrete; photos, actual experience, a specific manual, etc.
#12 in the parts lookup, float lockout pin,flip it one way the cylinder floats, the other it locks the float on the rock shaft.
![]() Quote:
How'd you guys let this thread go on 3 pages ![]() To be fair, when I first thought to put a sleeve hitch on my 782 I assumed I needed a lift block too until I took the tunnel cover off.
Here is a side by side comparison of the regular wide frame lift bar (top) and the 82 series lift bar (bottom). The front hole is recessed to accept the head of a clevis pin. I attempted to install it today and found out that I do indeed need that piece discussed above. The front end of the lift bar hits the clevis pin before the holes to connect the lift bar line up.
Well after comparing a bunch of photos I think the problem is with the repro bar. The hole at the front is drilled too far back thereby causing interference with that clevis pin. I'm wondering if I could get away with trimming off a bit. Any opinions?
Is the one on the left a repro? looks factory, or is the one on the right?
