Old 07-16-2021, 08:47 AM
EternalArianne EternalArianne is offline
Default Steering play
I was wanting to fix the steering play on my 2155. Ive seen videos of people replacing the bearing at the bottom of the steering column above the gear but it doesn’t appear the 2000 series has that? All I can see on the parts diagram is a bearing at the top of the column, under the steering wheel, the only thing around the gear at the bottom are washers and the nut. Would the bearing at the top of the column be the culprit, or does anyone have any experience with steering play on these 2000 series models?
Old 07-16-2021, 09:08 AM
There are a number of factors that contribute to "play" in the steering. First, I would look at the (4) 923-0156 Ball Joints. These are noted for getting worn out.
Old 07-16-2021, 09:11 AM
Sorry I should have been more specific. The play I’m referring to is where the steering wheel turns a good bit before the wheels actually start to turn.
Old 07-16-2021, 09:36 AM
Are you saying that the Steering Wheel moves but the Pinion Gear lags ?? Or is there "play" between the Pinion Gear and the Sector Gear?
Old 07-16-2021, 09:40 AM
I have to turn the wheel a good 1/4-1/2 turn before the wheels start turning. No wobble or shaking that I can tell.
Old 07-18-2021, 12:44 PM
dale c. dale c. is offline
look it over and see where the play is . very easy when you're at the tractor ,impossible for anyone not looking at it to tell you for sure where the play is .....
