My new 1512 has a broken aluminum case (pump adapter housing?) on one side where the front frame bracket attaches. Will installing axle braces from Xtrememotorworks completely fix the issue? How about also installing a rear hitch plate from a Cyclops (if the diesel fuel tank allows it to fit)? I want to tow and that would take the load off the transmission housing in addition to help stiffen the frame.
thanks! PS - I tried posting this earlier but its not showing up, so if it ends up a double post I apologize. |
Put a GT brace on it and the hitch plate and you are good to go.
Any problem if I can't get a hitch plate to fit? The diesel fuel tank sticks out back 1" past the top part of frame. Unless the hitch plate stands off the back of the frame by 1", I'll need to cut off the top of it to clear the tank. Guess I need to get a plate in hand and give it a look. I could always install a frame mounted receiver hitch to keep towing loads off the aluminum case.
That fuel tank is also keeping me from installing a 3 pt (sleeve type) cast lift lever. I wish there were a smaller tank available that didn't extend so far to the rear. I don't need a long run time so reduced volume wouldn't be an issue. |
I put a hitch plate on a 1572 with no problem.
I have a plate on a 1572 and have no clearance issues.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
I put a hitch plate on a 782D with no issues.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
