Old 02-03-2021, 04:21 PM
CubbyRI CubbyRI is offline
Default Poor idle, cheap carb, or worn engine, or???
Well my $17 china carb does run the 100. The engine does smoke from worn rings. I cant seem to get it to idle down reliably though no matter what I do with low speed jet screw. If I get it idling, after a minute it peters right out
It starts right up with no problems (with half throttle and choke).
Not sure if these carbs are known for these issues, or, what else it could be with these idle difficulties...
any advice appreciated!
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 02-03-2021, 04:32 PM
Cubcadet_107's Avatar
My Chaiiii-naaw carb idles my 107 just fine
Perhaps there's some sort of casting material stuck in the idle circuit?
I can't think of anything else if it's a brand new carb.
My Original won't idle without partial choke, but it's got the original carb still. I just gotta get around to cleaning the fuel system up.
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 02-03-2021, 05:03 PM
I have a china carb on my 108 and I've never been impressed by it. It idles like crap and it's not consistent at wot. I'm planning to go to my buddies house one of these days and buy a bucket full of used carbs and just rebuild them or use them for parts as needed.
Old 02-03-2021, 05:46 PM
I got one just for the hell of it. The fuel shup off needle jet has different threads than the OEM carbs.
Do you have the idle stop screw adjusted properly?
Old 02-03-2021, 06:28 PM
That was one of the adjustments that I worked with in addition to the idle mixture... nothing seemed to make it happy for any thing longer than about a minute
Old 02-03-2021, 07:22 PM
ironman's Avatar
ironman ironman is offline
Did you replace the carb just for the heck of it
or was there a problem before you replaced the carb.
Maybe the problem wasn't with the carb.
I've used about a half dozen Chingchong carbs and
the only problem I ever had was some dirt in the float
needle seat and I don't think it was the carb's fault.
Old 02-03-2021, 09:13 PM
I bought the tractor recently and the carb was a lump of unsalvageable rust. The china carb was cheap and I though too simple technology for even them to screw it up. It could be just adjustment, as u said debris, or whatever. But i wanted to throw it out here in case these are all problem carbs or what... sounds like so far, the consensus is that they are not necessarily bad ...
I'll take it off and blow out the passages etc...
Old 02-04-2021, 08:44 AM
ironman's Avatar
Do some carb swapping with something that runs right and you'll have your answer.
Old 02-04-2021, 12:33 PM
ICOM 756 ICOM 756 is offline
just tossing it out there..
burns oil.... bein rings are toast. maybe heat and head warps . lose compression.
piston is out of round so on ..
fouled plug
cruded up valve seats.
pop the head its easy enough to do..
cornfused. i see 2nd post now.. so is it idling ???? after you did the head ?
Old 02-04-2021, 12:49 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Sometimes people think when engine "peters out" at idle, they think they need to richen the fuel flow at idle. It may be the wrong thing to do since engine may be loading up with fuel and it stalls. Try the opposite... Go leaner. Looking at the spark plugs tells the tale but that's hard to do if you have a bad smoker.
Plow blade
#2 Cart
QA36 snowthower
