Old 01-16-2021, 03:21 PM
ReicheC's Avatar
ReicheC ReicheC is offline
Default What removes hy tran grey goop?
Changing the fluid on my 782. There is snotty grey goop above the 'water line' on the upper parts of the rear end. This is probably water encapsulated hy tran. Brake clean doesn't seem to touch it. I've wiped most of it out with blue shop towels but was wondering if there is something that will melt it off so it is cleaner.
Old 01-16-2021, 03:34 PM
First, welcome to OCC.........
Did you try Acetone or Lacquer Thinner ??
Old 01-16-2021, 04:09 PM
ReicheC's Avatar
An acetone soaked rag, while a little aggressive on the reddish paint on the inside of the rear, did a pretty good job at loosening the stickiness. I got most all of it out. Thanks
Old 01-16-2021, 04:23 PM
The "red paint" is actually a product called glyptal. It is used as a cast iron "sealant".
Old 01-16-2021, 06:16 PM
SDBOB SDBOB is offline
When I got a 1650 the rear was pure grey white. I slanted tractor to rear. I wiped and washed it out for a week about half hour each just took my time. Used kerosene.
Old 01-17-2021, 09:15 AM
FWIW:
Glyptal is also highly recommended as an insulation for windings in electrical motors/generators etc.
Old 01-17-2021, 01:37 PM
charlie105's Avatar
charlie105 charlie105 is offline
Default Grey stuff
Does a magnet attract it ?
Tags
cleaning, goop, hydro
