https://www.onlycubcadets.net/forum/...ad.php?t=55602
Been a few months since I posted my intro.... Lol. It's been since August 2019! Finally got some time to work on it during the pandemic.... Since the engine was confirmed to run properly, I tackled the axle seal leak that was making a mess. As per directions found here, I bought a complete set of seals for the rear end and pump. Turns out someone had been in the rear end before and put the date on there. I do the same thing when I service one of my regular tractors. I pulled the axle and seal and saw it had probably gone in cockeyed and that's why it as leaking so much. Proceeded to do the same with the first replacement seal. Fortunately I had two since I wasn't going to do the other side. Second one went in fine. Cleaned up the cover and put back together with a new gasket. No leaks! Started running new fuel lines and found a tank seam busted and cracks in the bottom. Replacement should be here soon. Rigged up a homemade pvc pipe gas tank and new fuel pump. This Kohler sure sounds smooth (after cleaning out the carb of course). Then while hooking up the safety switch (had to rewire the machine) I noticed the pedal marked "Brake" wasn't actually connected to brakes . :| The pedals on the right side work fine. Anyone with a hint as to what this pedal connects to? The two for the right foot operate the actual brakes. I see the jackshafts and metal tabs for left foot pedal, but they're not connected to anything. Pics too big to post. Will figure out how to shrink them with this new phone. |
According to the 1864 Owners Manual, the left pedal is for "brakes". They make no mention of RH pedals.
Sounds like you already have a plan for the leaking gas tank but just
for the sake of information. I have repaired quite a few leaking plastic tanks with a product called Seal All. Even repaired seams with excellent results. Ken |
Pictures as promised.
I actually ordered a plastic welding kit to fix the popped seam but after seeing all the cracks on the bottom decided it wasn't worth it. This is the third white plastic tank I've had that suffered this problem. The replacement is an older black plastic tank. I've never tried Seal All, but I just looked it up. Sounds like a great product to have on hand! I had reason for buying a new tank though-- check out the internal gunk inside mine. I could not get that sticky tar off and was intending to run with lots of spare filters on hand. So..... the two pedals on the right side operate the right and left brake calipers. What's the pedal marked brake supposed to do? It moves the tab I've marked with the red arrow. There's one on each side but that's not connected to anything! FYI those self tapping metal screws on the footrest are from me cobbling together a hinge mechanism for the replacement seat. Predrilled with the screws to hold everything together and then replace with bolts. My tractor came with all the plastics in good shape, but missing the air filter cover, seat, and seat base. |
Wow, Seal all is great but have to admit I'm don't think a crevice like that
would be a good candidate. Like the clever PVC gas setup. Ken |
The pedal on the left with the locking lever is the parking brake.
It should force the hydro to neutral and lock on the brake. My 1864 has no right pedals. My 2084 had right pedals, they were steering brakes which i thought was a SGT thing?
JD x475 |
