Ok, I'm getting ready to do the trunion repair on my 782 and I am not real sure how to get the speed control bracket off so I can get to welding up the trunion? I can see down where it conects bot unsure of how it comes off?
I just threw some wet rags over my hydro when I welded mine...
Gary '49 Farmall Cub, '62 "Original, '70 73 w/402-D Haban sickle, '71 127 w/38" cast end deck, '73 149, '76 Sof76, '07 LT1045 w/bagger, '09 GT2544 w/bunch of mods. 5 Exmarks, Kubota B2920, blah, blah, blah... |
I plan on doing the wet rag thing but I want to remove this bracket so I can repair it also. It is very worn and needs to be re-shaped also. I can't belive how dirty this beast is! I started to scrape all the years of dirt from it. The arrow points to the rod but I do not see a way to remove it? The pics i have found for the repair show this bracket removed from the pump?
There should just be a snap ring on the outside end of the rod.
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
WOW...that's worn really bad...you can see where the little button on the trunion spring is about to come through the side of the rectangular hole.
jbollis, is correct. There is a snap ring right where your arrow is.
If it were mine I would pull the transaxle out, wash it and then repair the trunion. A clean transaxle runs a lot cooler than a dirty one. Plus, it's a lot easier to repair the trunion with the transaxle out of the tractor. Just my opinion... |
my trunion bracket looks like zelda's. Except, both corners are worn so bad from the spring end caps they are super close to going right threw the little metal that is left.
1. What will happen if this problem is not repaired and the end caps go threw the metal? 2. When the trunion bracket is repaired, can I reuse the springs and end caps? Thanks for the help again. |
