I need to replace the clutch spring on my 582. I been think of getting a blue pulling spring instead of stock one, just looking for opinions on this. I use it to pull my heavy dump trailer and plow pull logs.
thanks, Jeremy |
I used a blue spring on a 100. It has a good feel to it. Mike
You ever slip the clutch with the old style spring? If not, then you don't need a heavier one. If yes, then it would be a good idea. It's your money.
Good exercise for your left leg but stock springs will spin the rear wheels with chains on them.
I agree with all above. We run VW aircooled sandrails. Easily doubled the hp of those motors. As far as the driveline goes. Somethings going to break at some point. Make your weakest link cheap and easy to fix.
I run chains, and spin every so often. I'm hesitant to add weights, in addition to a 200lb hairy gorilla. The wheel spin is the weakest link. If I was constantly spinning and not getting the job done time to reevaluate.
![]() ![]() ![]() '76 1200 Dad bought '75 1200 "Twinsie" per my daughter |
My wife uses it as much as i do and has never complained. Mike
mike did you use the roll pin or split collar. main reason i can get blue one for cheaper then a stock one. but wanted opinions
That one used a roll pin with a new driveshaft. Trued up pressure plates and a used throwout bearing. Maybe a couple extra washers. The blue ones are a lot less stlff than a red pulling spring. Mike
ok thank you
