Morning all,
I've got a rather serious problem. Somehow the 2 bolts attaching the right side frame to the rear end came loose and fell out. I can't seem to get new ones to engage the threads, I'm afraid they are striped out. I'm guessing my only choice is to disassemble everything, drill out and put in heli-coils. Any other suggestions would be greatly appreciated |
Are your new bolts long enough? Those right side bolts are pretty long.
There are 4 - 3/8-16 X 2 1/4" bolts and 2 - 3/8-16 X 2 1/2" bolts.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Thanks for the replies, very helpful. I think I was using 2 1/4" don't really remember. Are there clearance issues if I would use longer bolts ?
I can't quite tell on partstree, are those through holes into the diff.? If I chase the threads will crap get in my fresh oil ?
![]() Quote:
Well.... yes. They are open to the oil cavity. You've got troubles. |
