i recently got a 782 it has the cast rear end no drain valve or fill other than the plug got a new filter and rear gasket what the best way to get fluid back in it thanks kenny
Pull the rear cover.
The rear cover should have a plug in it, remove the plug and fill it through the hole until it starts to run out. A funnel with a piece of hose on it would be helpful.
i knew i had to pull cover but is the plug npt i thought about screwing a nipple a 90 turning the pipe up with a fill cup up high has anyone tried it holding a funnel and hose for 7 qts seems time consuming and messy thanks kenny
I use a 90. Works fine.
is it 1/2" npt i was thinking a nipple a 90 another nipple and like a 1/2"x1 1/2 reducer thanks
Do not use 90 in a hydro.
Edit: My bad I didn't realize that you were talking about a 90 degree elbow. Thought you were talking about 90wt gear oil.
You can remove the top cover and pour it in till it runs out of the plug hole if you have the fenders off.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
![]() Quote:
As I am approaching proper fill level, I will use my pinky as a dip stick to test the level. Once I am close to the fill plug level, I pour it in the funnel by the cup full with a drain pan underneath so that I don't have a giant mess on the floor.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
