Old 05-27-2010, 05:51 PM
ghoch ghoch is offline
Default Reviving a 127
Hello fellow Cub Cadet fans,
This is my 1971 127 I bought from the original owner back in 1986 for $500. I used it for mowing in Royersford, PA, then in Culpeper, VA, then in Haymarket, VA, then in South Bend, IN (We've moved a lot). Then we moved to Sussex Co., NJ in 2000 and with almost no grass to mow it has been relegated to the shed for the past 10 years. We also have a property in Tyaskin, MD(lower eastern shore of the Chesepeake Bay) and just purchased an adjacent cleared lot. So, after its long rest, the old Cub Cadet is finally needed again. After lots of fuel system cleaning I finally have it running pretty good. However, it's not charging the battery and I am looking for a little advice on this(I have grounded everything exstensively). If the starter is working fine does that indicate that it should also be functional as a generator? Is there a simple means to determine whether the voltage regulator is functioning correctly? Any help will be greatly appreciated.
This is a very impressive web site and a great testimonial to a fine little piece of machinery.
George
Old 05-27-2010, 10:24 PM
ghoch
Check out this link It might help you get started trouble shooting.
Let us know what you find out.
http://www.onlycubcadets.net/forum/showthread.php?t=18
And
Old 05-27-2010, 11:15 PM
Cool 127, George! Glad you are still enjoying your tractor all these years.
Old 05-28-2010, 01:31 AM
George
Old 05-28-2010, 04:24 AM
camarokidz28's Avatar
Denny
Original Member # 389
Saw It
Wanted It
Had A Fit
Got It
Old 05-28-2010, 07:01 AM
Thanks for the welcomes! That is exactly the troubleshooting info I was hoping to find. I will let you know how I make out.
George
