Old 11-20-2016, 09:31 PM
Arik434 Arik434 is offline
Default PTO belt replacement, now runs constantly?
I replaced the 2 PTO belts on my 3184. It seemed like a pretty straight forward job, but now, as soon as I start the engine, my snowblower is turning. The PTO seems to be engaging and disengaging fine, as I can see the PTO pulley release and stop spinning. Should the engine pulleys be spinning inside of the belts until the PTO activates and tightens up the belts? These are aftermarket belts, but when I quickly compared them to the belts I took off, they seemed to be the same length. Or do I maybe have an issue with the PTO brake lever? The spring is keeping that brake shoe down in the pulley, but thats about all I can tell. I guess I'm hoping that maybe the belts are just snug, and once I put some load on the snowblower, they will wear in a bit?
Old 11-21-2016, 09:50 AM
Oak is the 3000 series master, shoot him a PM.
Old 11-21-2016, 03:08 PM
I thought I had a better pic but is this how yours looks? This one is missing 1 belt but you can see the slack in the belt and the brake touching the output pulley. Make sure you have the two shoulder bolts on the bottom bracket, I think that holds the belts up when not engaged.
Old 11-21-2016, 03:22 PM
Yes, pretty much the same setup. Seems like maybe my belts are just too tight. My brake rod spring seems to be mounted slightly different though. Maybe that rod needs adjustment. Does that brake keep the lower drive pulley locked when the pto is disengaged?
Old 11-21-2016, 06:38 PM
It stops it from turning but you can spin it by hand. What belts did you use?
I have used these on my mil's 3165 before and they worked well.
http://www.ebay.com/itm/CUB-CADET-MT...item19d1f00a2f
I used the OEM ones on my 3205 and they are great but a little pricey.
http://www.cubcadet.com/equipment/cubcadet/954-3084
Old 11-21-2016, 07:41 PM
These are the ones I used...they seemed to have good reviews and are the right size as far as I can tell.
https://www.ebay.com/itm/110795079785
