Old 10-18-2016, 06:19 PM
chief's Avatar
chief chief is offline
Default New Lawn Mower Lift
I built this new lift to clean under my mower decks and remove the blades to sharpen them, The post is 30 inches in the ground,
And the Boom is 9 feet long, And has A 8 ton air jack,
I'm not sure how much I can lift with it yet,
But the GTX-1054 on the lift Is 587 LB'S
And the Boom will swing around 180 degrees,
104 1650 LT-1018 GTX-1054
Craftsman YTS-3000
1951 Farmall Cub
1953 Freguson TO-30
Old 10-18-2016, 07:01 PM
DieselDoctor's Avatar
Just remember that safety is not an option. Use some jackstands when working under the hoist. Your homebuilt crane looks to be a very handy tool, I like it!
Old 10-18-2016, 07:38 PM
Looks like the post is bending. Suggest that you shorten the boom.
Old 10-18-2016, 07:46 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
I would be very leery of it's mounting! Research "Jib Cranes" and see how the base made and reinforced. You have a great deal of leverage suspended on, what looks like, a little bit of concrete. For your safety you may want to re engineer its mounting platform and re enforce the concrete. Otherwise, its a great idea and a handy tool!
Queen Of The Quietlines!
Old 10-18-2016, 07:51 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Yep! Don't ever get under anything hanging by hydraulics.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-19-2016, 03:05 PM
chief's Avatar
Thanks for all the advise, and I am a safety NUT,
The pipe was bent before I put in the ground and is 3/8 thick
the outer pipe is 4 inch and I cement it in a 9 inch by 35 inch deep hole before I poured the floor.
and I always use jack stands when working under anything
because I just turned 70 on September 27 th.
you all be safe out there your self
Craftsman YTS-3000
1951 Farmall Cub
1953 Freguson TO-30
Old 10-19-2016, 05:07 PM
BAD IDEA.
I'd rather see you use a jack.
Really? A 9' reach and you think this is safe??? I wouldn't get close enough to it to put jack stands under it. Besides..... I'm really doubting you have jack stands that will hold it as far in the air as you have it in the pics. I'm betting you just stay to one side and clean out the deck with nothing but the crane holding it up.
