Old 10-12-2016, 09:47 AM
TN_Explorer TN_Explorer is offline
Default Can I use these dual wheels on my 782?
I have a chance to pick up a set of dual wheels/tires at a good price. They are the right size but the wheels are 6 lug. They came of a Sears, but the seller believes they will fit. I think they have to be 5 lug to fit.
The long bolts connect the two rims together, but doesn't the inside wheel need to bolt to the tractor hub (5 lug)? That means I can't use these, correct? They are loaded and so will be difficult to transfer to my rims.
Old 10-12-2016, 09:58 AM
If your just going to use those wheels on the outside then they should work, 6 lugs doesn't matter on the outside wheels.
Old 10-12-2016, 10:08 AM
IF those are 12" wheels AND the rings fit where they should on YOUR existing wheels AND the holes (for the long bolts) match up with the holes in your old wheels, you could use the ones in the picture as the outside wheels on your Cub.
Those are some FUNKY looking wheels, from the picture they look like someone welded those centers into the wheel.
Take a Cub wheel with you to see if everything lines up.
Old 10-12-2016, 10:11 AM
That's a solid piece of advice right there.
Old 10-12-2016, 11:59 AM
Dane in PA Dane in PA is offline
If they came off of a Sears, they're off of an FF18, 20, or FF24. The hulks or "Supers" of the Sears world. They had 6-lug hubs, and usually ran 26-12-12 tires on 12-12 rims. So, the tires may be big unless you already have 26-12-12s on your 782.
Old 10-12-2016, 12:21 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Default Duals
You need some DMI type duals that slip on and bolt in
Old 10-12-2016, 12:58 PM
Did you make those? Or buy them? Or is it just a pic off the net?
Old 10-13-2016, 10:23 AM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
I think that's where the spacer was bolted against the rim. The paint is just more intact.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 10-13-2016, 12:31 PM
Default DMI duals
I made them a few years back.Not much market for them so I only made a couple of sets.My 782diesel utility has a set for 26-12-12 tires.The other ones were for 23-8.50-12 tires.I put bigger rods in mine the originals were 3/8'' and I used 1/2''.
Old 10-13-2016, 12:37 PM
Pictures of the 26-12-12 duals
