Old 10-06-2016, 07:22 PM
Tom_c Tom_c is offline
Default 109 PTO fiber button
Hi,
I have to repair a PO's mod of the PTO rockshaft on a 109.
There is no place for a wear button, so I have to recreate the original release.
My question is, what size hole does the fiber button wedge into? I have the button on order, but would like to start the repair.
Thanks, Tom
Old 10-06-2016, 07:29 PM
How bout a picture of your pto arm?
Up to 530 and counting...
Old 10-06-2016, 08:20 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Originally Posted by Tom_c View Post
Hi,
Check very closely. Mine looked the same, as though someone welded the hole shut. I took a punch and knocked out what presumably was the old fiber button that broke off.
I've attached a pic of what mine looked like.
If, somehow, they filled the hole and cleaned it up, get a brass button from Jeff.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 10-06-2016, 09:53 PM
Default The mod
Here is the mod,
somebody thought it would be a good idea to weld this onto the original arm.
Obviously a bad choice, you can see the inevitable destruction of the PTO levers.
So, I have to cut all that off and start over with a flat piece of steel and a hole for the fiber disc.
Regards, Tom
Old 10-07-2016, 08:19 PM
vr4Legacy's Avatar
Well then, there certainly isn't a broke off button in there...
I suppose that "worked" if the thrust button was broke...
Sorry, I can't provide the diameter, I remember it was an odd size because I was going to run a drill through mine and I didn't have a bit the exact size.
Good luck with the repair. I just rebuilt my 149 PTO, isn't too bad of a task. Let us know if you have any questions.
-Jason
Old 10-07-2016, 08:56 PM
Hi,
As I look at this mod, a thought occurred to me, the PO probably had a bearing in that cup you see in the photo, which could have worked, but the implementation was not great and the bearing failed, taking out the Pto levers.
Old 10-07-2016, 09:16 PM
budscub's Avatar
budscub budscub is offline
Default Thinking the same thing.
Hi,
I thought the same thing when I saw it. I suppose it worked for a while. . Problem is the flaw in the PO;s thinking. As the point of contact is on a swinging arm, perfect alignment of the bearing to the release button would be almost impossible to maintain. So as the bearing contacted the release button there would be not only a radial load but also an axial load on the bearing, IH did it right with the flat contact button.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 10-07-2016, 09:44 PM
Here is the mod,
Regards, Tom
That is screwed up bad. I would only repair that if a replacement could not be found.
I would offer to repair it for you but postage to our friends up North is "stupid expensive" thanks to the USPS rate increases.
Old 10-16-2016, 10:11 AM
kenm1975 kenm1975 is offline
Thumbs up
I bought a replacement pto though out rod for $10.00 from Miller's Cub Cadet Parts
Old 10-16-2016, 05:01 PM
I'm confident I can fabricate something using this shaft, I was hoping someone would know the hole size, but I can probably figure that out when I receive the fiber button.
