It is possible to check the v/r for a s/g tractor without having it running? Like ohming it out? Also sorry for being gone for a while guys...work has been busy plus I've had some projects to finish up
Brandon CC models: 86, 1650, 100 w/hanban sickle mower & 1872 1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade 1978 1650 Hydrostat w/44" mower & 42" IH push blade 1965 100 w/hanban sickle mower 1989CCC 1872 w/50c mower |
YES and NO.
You can check resistances IF....you have the specifications to compare to. To check amperage and voltage, you need a functional charging system.
Is there a reason you need to test it without the tractor running?
Just got a newer s/g yesterday. Have a V / R off another tractor but cant remember if its good or bad
In that case I would go ahead and install it and see what happens.
Kinda iffy too. My last one burnt up.
