Old 04-13-2009, 09:36 PM
tubbyfirefighter's Avatar
tubbyfirefighter tubbyfirefighter is offline
Default Mule Drive Question
Are the pulleys on the mule drive supposed to be the same distance from the front of the tractor? Im new to the cub cadet facination and need to learn all I can. Thanks
Old 04-13-2009, 10:54 PM
young enthusiest's Avatar
no, they aren't. sombody with more knowledge will most likely post a link to proper tension
Old 04-13-2009, 11:56 PM
murphycc
Guest
Posts: n/a
Mine are an inch or so from center with eachother IIRR more or less. No not neccessarily. As long as the belt is tight and the pulleys are clear I'd not worry about it.
Scott
Old 04-14-2009, 12:07 AM
Jim H.'s Avatar
Jim H. Jim H. is offline
If you go to the tech library you will find the topic with pic [posted by our own R Bedel.
To improve belt life, a proper alignment from the PTO drive pulley to the center pulley of the deck is imperative. Also, is it important to use the correct belt.
Every time I find the key to success, someone changes the lock
Old 04-14-2009, 12:37 AM
murphycc
Guest
Posts: n/a
Ah yes centered under the engine pulley but the tension pulley will not stay aligned to eachother, as least mine don't, allows for movement.
Scott
Old 04-14-2009, 09:34 PM
Jim H.'s Avatar
PTO belt streched ?
or wrong one.
Old 04-16-2009, 08:50 PM
ok so i was under the tractor last nite at midnight and noticed that the pulleys were severly offset! The pulley with the treaded bolt is fubared. looking at the belt, it looks like its the wrong size. it is rubbing on the spring that is attached to the pulley bar. what size belt do i need and can i get the bolt that holds the pulley in place from a local hardware store or does anyone have one laying around that they wouldnt care to part with?? the bolt looks like it has just a hook on the end that goest to the pulley bar thanks for all your help.
Old 04-16-2009, 10:17 PM
Jim H.'s Avatar
http://home.comcast.net/~dos0711/CCBELTCHART.htm
From the Tech Library
Old 04-17-2009, 06:48 AM
tubbyfirefighter:
What model of Tractor and deck do you have...??
Old 04-18-2009, 07:26 PM
1250 frame w/ 16 hp koler with a 50 inch deck
