Old 01-12-2016, 05:36 PM
Ikea6e Ikea6e is offline
Default Hyd Lift Valve
Switched out the M18 for a CH18 in the 1862 with a 451 blower, works nice.
What caused the lift valve to want to stay open when lifting the blower? O ring sticking? Internal spring too weak? The one on my mowing tractor does the same thing periodically.
Thanks,
Ike
Old 01-12-2016, 06:56 PM
Thanks,
Ike
I'm lost on this one, what is it your asking?
Old 01-12-2016, 07:11 PM
I have a tractor the valve hangs on, either up or down. I have no idea what the problem is. I just make sure I center it when I get the emplement where I want it. Too much trouble to play Dick Tracy.
Old 01-12-2016, 07:23 PM
Mike,
Mine just does it when lifting the blower.
Thanks,
Ike
Old 01-13-2016, 07:58 AM
Mike,
Thanks,
Ike
I think my Cyclops valve sticks in both directions but I don't remember. The valve is probably just gummed up inside around the O rings.
Old 01-13-2016, 01:05 PM
Frank1541 Frank1541 is offline
On my 1541 the plastic valve handle was up against the plastic dash. It was only a problem in the cold. Did a little sanding and everything is fine.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 01-12-2016, 07:12 PM
gt383mag's Avatar
gt383mag gt383mag is offline
im guessing you have a cyclops and when you lift the blower the valve handle stays up? im guessing the handle has sticky pins? i dunno i just assume thats what MINE is doing i just got used to pushing it back and havent messed with it
Old 01-12-2016, 07:20 PM
gt83mag
Yes, that is what mine is doing.
Thanks, Ike
Old 01-12-2016, 07:18 PM
The lift valve sticks in the up (lift) position. Must be pushed down once the blower is raised.
Thanks Ike
