Hey guys, does anyone know which terminal is which on the voltage regulator for a 125? Mine isn't labeled...
Each terminal will have a letter stamped into it, you might need to clean up the terminals with some sandpaper to see them.
![]() Quote:
This might help. Hard to read; page 1-29 of the service manual, available in the tech section.
That's assuming he has a factory regulator.
Yep, you guys were right. It was stamped in it, but it was just really crusty and I had to clean it up good before I could see it.
So, I got it hooked back up correctly and now it goes full charge all the time. I'm getting 17+ volts at the battery. What should I check? Would a bad ground from the regulator base to the frame cause this? |
