Old 08-05-2015, 03:54 PM
dhurley572 dhurley572 is offline
Default Cub cadet 1282 issues
New to this forum but I was hoping you can shed some light on my situation. I went out to mow my grass yesterday and the tractor has been giving me issues for like a month or so but it is really bad now. Like a month ago I realized that it won't rev up unless it's on choke for about 5 minutes and when it gets hot it seems like it has a slight miss. Yesterday I went to rev it up and the whole tractor started to shake and cut off (violently)!!!! Any help????
Old 08-05-2015, 04:06 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
could be anything from dirty carb,bad gas,dirty fuel filter,worn plug,dirty air filter,deteriorated fuel hose.etc.... you need to do some digging and further diagnostics
Old 08-05-2015, 05:15 PM
ok thank you. It idles fine its just when you go to throw some RPMs at it, it doesnt like it at all!!
Old 08-05-2015, 05:30 PM
It sounds like some sort of fuel issue.
Start with the simple things first. Make sure you have good fuel deliver to Carb. Check the "Tank Shut Off Valve" and see if the screen is plugged.
If so, clean same and install "fresh" gasoline.
Old 08-05-2015, 05:37 PM
never knew that was inside the tank. thank you
Old 08-05-2015, 05:47 PM
In addition, make sure the tank is clean too.
