Old 07-16-2015, 10:18 PM
Wing Bucket Wing Bucket is offline
Default 782 ignition -- what causes this?
My 782 wouldn't start a couple months ago.... Narrowed it down to a connection on the back of the ignition switch. The blade with the green wire was really corroded and the female connector looked burnt. Replaced the connector, sanded the blade, and everything worked fine.
Yesterday, the same issue happened. Took the ignition out and the same story! Blade looks corroded and the connector was burnt.
Any ideas what's causing this? Maybe the ignition's just shot.
Thanks
Red 782 hydro with deck and front plow
Nothing like saving the day with something you didn't throw away!
Old 07-16-2015, 10:22 PM
Replace the switch and replace any/all burnt terminals.
Old 07-16-2015, 10:24 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
i,m guessing you didnt replace the switch when you did the repair,i would replace the switch and buy a repair harness. solder and heat shrink all connections. check the wiring for any areas rubbed thru,and the connector pin out location
Old 07-16-2015, 10:30 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
you probably have high resistance in the switch causing heat... like the others said.. replace the switch and the connector.. should solve your issue
Jay
Proud owner of the following:
Old 07-16-2015, 10:36 PM
The switch/connections is a trouble point on those.
As the switch corrodes over time, the connectors ark and get hot, more corrosion takes place and it goes down hill from there.
The switch spades are plated steel, the connectors are copper but upon close inspection they will be blue from heat, and lost their springiness and ability to stay tight insuring a good connection.
Usually the battery supply is the main culprit
To really solve it as mentioned, replace the connectors and the switch.
I'm a thrifty guy but replacement is the only sure cure.
Old 07-21-2015, 07:44 PM
BCDSFCRET BCDSFCRET is offline
Default Bcdsfcret
After 35 years of service it should of lasted longer!
your problem is common on 782s and 682s. I have replaced many of them over time.
Brian
Old 07-21-2015, 10:03 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Brian
I agree, all electrical parts should be able to last a minimum of 100 years
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 07-22-2015, 07:44 PM
I wish they did last 100 years, cause I'm no good with electrical!
Replacement is on its way. Sounds like the ignition itself just went bad, so I'm hoping plug-and-play fixes it fine.
Thanks
Old 07-22-2015, 07:46 PM
They do last for 100 years as long as you don't use them.
