Old 06-26-2015, 07:55 PM
Cub cadet 782d Cub cadet 782d is offline
Default 582 Engine Trouble/ replacement
I recently bought a 582 for $200 and the engine was out because the previous owner said it blew oil through the carb. So my question is should I rebuild the motor it has been sitting for a while and there are mud dobbers(wasp nests) in the motor itself and it is missing some parts, or should I be looking for a motor to replace the old one. What would be a good motor to put in it that will bolt up pretty close the the original. Thanks.
Old 06-27-2015, 06:44 PM
woodydel woodydel is offline
Oil through the carb. Do yourself a favor and check a couple of things. Check the breathers and check the oil fill/dipstick cap is sealing the crankcase. No vacuum in the crankcase will deposit oil in your air filter housing.
I bought a 582 with an engine "which threw a rod" according to the farmer.
Took it home and found the bolts loose holding the engine to the mounting plate. It slid forward enough allow the clutch drive pins to slip out of the clutch. I'm sure it sounded like an engine "which threw a rod".
My point, don't automatically believe the diagnosis from the seller.
You can see this happen with an ordinary lawn mower with a briggs engine. Leave the oil fill cap loose while engine runs, watch where the oil ends up.
Old 06-27-2015, 11:17 PM
Ok thanks I will have a look at that and see what we find out.Where is a good place to get parts and maybe a rebuild kit for the engine.
Old 06-27-2015, 11:22 PM
The B&S engine in the 582 was notorious for valve seats falling out. It made the carb puke gas and a lot of time burp oil up the vent. No easy way to fix and no cost effective kits that I can find. Pull the plugs and look in the cylinders. You will see it if it's a valve seat. If so just stop and look for another motor.
There was a guy on here recently that tried to put a CH in a 582 and had to do quite a bit of work to get it to work. I didn't think it looked like a big deal.... but I have a lot of experience. Anyway... No real good "direct swap" out there for it, but yes, you can repower.
Old 06-28-2015, 02:06 AM
Do a compression test. Get a shop manual.
Old 06-28-2015, 08:40 AM
Mike in SD's Avatar
Mike in SD Mike in SD is offline
A repower with a Kohler Magnum is as close to a direct swap as you get. I just finished putting a M20 in my 582 and it wasn't too bad. The hardest part is finding a good Magnum that is reasonably priced.
HTH,
Mike
'62-O, 2-100, 71, 2-122, 2-123, 72, 127, 147, 108, 128, 149, 169, 2-1450, 582, 3-682, 2-782, 1811
1940 Farmall M, 1955 Farmall 300, 1967 Scout 800, Many Scout IIs, 1968 1200c 4x4
Old 06-28-2015, 09:22 AM
Justin Witt Justin Witt is offline
Jon, how does oil start to spill into the carb when a seat comes loose? Wouldn't that just cause it to loose compression? I worked on a mower that the seat came out and it was making it so the valve wouldn't go back in, so it didn't have any compression.
Old 06-28-2015, 08:44 PM
Plus seats are supposed to be re-staked as maintenance . Briggs knows they come loose not just on the twins but ALL.
