Old 05-31-2015, 01:14 AM
105_Tom's Avatar
105_Tom 105_Tom is offline
Default Oops, I did it again: Cub Cadet 1650 w/attachments
After redoing all of the associated ISO-mount stuff on my buddy's 1450 a few years ago (which is still working and running great) and having owned 2 1250s and very nice 1450, I decided to take a BTDT approach and swear off all future Quietline purchases. However... this 1650 with attachments came up (5 hours round trip smack in the middle of rush hour, no less) and I decided to bite. I was really after the #2 tiller, but I got everything you see (and even some stuff you don't see) for little more than market rate for a complete tiller setup. Of course I'm missing the long belt and mule drive with the solid pulleys, but everything else is there and the tiller spins free and was stored inside. I haven't had a minute to even get everything off the trailer yet, but visually the tiller looks pretty good from others I've seen for sale. I'm still debating, but I think it will wind up on my worker 125 with hydro lift, so I would have had to get a new belt anyway. I have a couple of spare mule drives, so I may just need to track down some solid pulleys and threaded-bolt tension adjusters.
The other goodies include a lightly used snowplow, chains in an IH burlap bag (nice!) and a PECO Vac that is responsible for the sooty fender and melted right-side taillight Everything is there for the PECO Vac, so hopefully it will be a selling point for the tractor.
The 1650 itself needs to be completely gone through. I was pleasantly surprised to find the motor mounts to be solid and secure and the muffler box to be in great condition. The 50A deck looks promising and spins free and quiet but that's all I know about it for now. The X factor is that the tractor threw the driveshaft for some reason. Broke the adapters on each end and tore up the flex discs. Put some unsightly bends in the hydraulic lines and punched a hole in the hydro filter. I had expected the ISO mounts to be shot and the motor pitched at a jaunty angle that would have caused this, but no, it's right where it's supposed to be. The input shaft on the hydro pump spins free, so I'll just have to put it all back together and see how she runs with a good shaft installed. I'll get the tractor pulled down to the frame and power-washed and cleaned up over the next week and see what I have to work with. I think there's good bones under the dirt and grime and soot, and if the ISO mounts truly turn out to be good, I'm several steps ahead in this project. It did come with the side panels and tunnel cover, and it still has the belt guard for the tiller attached to the tranny.
More pics to follow once I get her unloaded...
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 05-31-2015, 08:58 AM
RichardNoggin RichardNoggin is offline
Tom,
Congrats on the score. I was in the middle of getting directions from the seller when he told me he had just sold it. I was waiting for it to show up on the site. For the price you paid it was a great deal "maybe even a Lew deal". Like you, I was after the attachments, the tractor was a bonus. Glad it want to an OCC member.
127, 129, 149, 42" blade, 2A Tiller
Old 05-31-2015, 09:13 AM
Darrell Darrell is offline
Nice find !!!
The driveshaft didn't break the steering box ?? That is another thing the driveshaft usually gets.
Old 05-31-2015, 10:53 PM
bkw3614 bkw3614 is offline
Great find, Tom! Despite what many say, I think a Quietline is a great tractor, once the ISO mounts are installed properly and adjusted to the machine after break-in.
I wish I could find a tractor deal so well accessorized. You made out well.
Old 06-01-2015, 10:53 AM
sawdustdad's Avatar
Congrats on that haul. Did you come to VA to get it? (only because you beat richardnoggin to the punch)
Old 06-01-2015, 11:30 AM
105_Tom's Avatar
Hey, all:
I did indeed manage to be the early bird on this one. Mind you, I've had plenty of deals slip away from me over the years so I was happy to have the chance to act on this one. And yes, it was a brutal 5 hour trip from Baltimore to Northern Virginia (Manassas) right in the middle of rush hour to ensure that I could put my hands on it, but its been worth it so far.
I got everything pulled apart and power-washed yesterday. The tractor cleaned up well, but I am going to do a full upgrade/replacement of the engine cradle and ISO mounts. It had lost one motor mount bolt, and another was loose, so the rails were definitely beginning to spread, as evidenced by the wear on the axle crossmember in the photo. I'm ordering the $28 set off ePay today, and I'll be on the hunt for a piece of steel stock to do the engine cradle mod since the pre-fabbed cradles are NLA from Patton Acres. I need to inspect the oil pan itself today and determine if the motor mount holes are clean enough to proceed with or if I should get a cast iron pan while the motor is out and everything is accessible.
The 50A deck is in really good shape and is just missing a grease zerk on the left spindle. Remember I said the guy gave me a bunch of belts that I really couldn't figure out what they were for? Turns out is WAS the long belt for the tiller, it was just coiled and twisted up to look like 3 belts The tiller itself cleaned up well and the tines and rotating assembly look and sound good. Just gotta make a mule drive out of the spare parts I have laying around.
It looks like the driveshaft adapter on the tranny end had been cracked for a while judging by the different rust on the two adapters, and eventually let go and caused the front one to fail and the flex discs to rip out. The hydro filter was cracked and cocked and I feared it may have damaged the mounting threads on the tranny, but all was well after I got it off. I had a spare CC filter on hand from a previous project and once I installed it, there were no more Hy-Tran leaks. So, I'll be chasing parts down this week and next, getting the cradle mod fabbed up, and no doubt a trip up to Ray Weaver's for all of the other stuff to make this a nice tractor again.
Tom
782 CCC Red w/44C
2072 w/60" Haban
Old 06-07-2015, 11:21 PM
105_Tom's Avatar
Default Progress
Been working on the 1650 as time and weather permits. Lots of progress, although it seems like little steps at times. I got all of the little stuff I needed for the tractor last week. Small stuff like another taillight, another lens to replace the cracked one off the left rear, a speed control knob, side panel spring, cast oil pan, fuel cap/gauge, and a driveshaft with all of the couplings. I rebuilt the driveshaft tonight with 4 new flex discs and a new plastic fan. Everything looks good, but I need a picture of the motor end of the driveshaft coupling to make sure I get everything right on mine. It was apart when I got it and I don't have anything to reference by. If anyone has a file pic, please post it. I put the cast oil pan on and the internals looked great on this motor. I have the rails stripped where the flat bar will be welded tomorrow and the old pan will be used to hold the rails in place for the cradle mod. I'll also have the welder tack a piece of keystock on the trunnion where it's worn grooves in the outer edge. I also aligned the front wheels today and tightened up the tie rod ends. All four castle nuts were finger loose after the cotter pins were removed. This caused most of the excessive play in the steering. The 50A deck got a new grease zerk where one was missing on the left spindle, but I still need to remove and sharpen the blades before it goes back under the tractor. Oh, and I also did the lift handle flip. It's so easy; every Quiet Line should have this mod done to it. So much easier when plowing or using a snowthrower.
As for the ISO mounts, I've decided to reuse my uppers and use 4 of the 8 that came in the ePay kit. My uppers are in excellent shape, so I'll move them to the bottom and put new uppers in from the kit. Plus then I'll have 4 mounts on standby incase I should somehow wind up with another Quiet Line I'll start with a thread and a half showing and go from there. After the cradle mod is done tomorrow and it gets a quick coat of CC Yellow, I'll be just about ready to start putting everything back together.
Tom
782 CCC Red w/44C
2072 w/60" Haban
Old 06-08-2015, 12:15 AM
105_Tom's Avatar
I think I figured out what I wanted to know about the front of the drive shaft. It should only have 1 flex disc, right? Two on the tranny end, and one up front. I can get it back together from here...
Tom
782 CCC Red w/44C
2072 w/60" Haban
