Old 05-22-2015, 02:29 PM
timbo2's Avatar
timbo2 timbo2 is offline
Default PTO off Model 70
Removed the beat up PTO from my model 70 project.
Notice the crazy set screws this thing had. I used a flywheel puller converted to bearing puller that worked ok. I got that idea somewhere here.
The collar came loose after removing nut set screw and hitting several times with a punch clockwise.
Does the collar attatch or thread onto the bearing? since not all use that nut set screw , how does it attatch?
some pics:
- Tim
Old 05-22-2015, 02:39 PM
Terry C's Avatar
Terry C Terry C is offline
If you look close the collar and the flange they work by being not concentric to the hole for the shaft. That nut and set screw is a PO mod I would say
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-22-2015, 04:43 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Some collars (I think O.E.M. for sure) have the set screw with lock nut on it on the concentric collar.
Looks like the basket needs to be corrected to the right of the set screw access hole.
Old 05-22-2015, 04:52 PM
Terry C's Avatar
My nuts must be missing cause I'm on my third clutch and I've not seen any lock nuts. Maybe they were all worked on previously.
Terry
3225
Old 05-22-2015, 05:09 PM
timbo2's Avatar
Double - not sure what you mean regarding the basket.
- Tim
Old 05-22-2015, 05:28 PM
Terry C's Avatar
The "tooth" to right of the tooth with the access hole looks like it's smashed down is what 07 is saying
Terry
3225
