I used pressure washer to blast all the grease and crap off my 104 this after noon and now my clutch seems to be slipping. Also i can not seem to get clutch basket to stay tight. Any ideas?
John |
Trans clutch, or PTO clutch????
Probably needs to dry longer
1961 Original 1962 original w/ fenders and creeper 102 72 w/ fenders and lights 124 w/ sleeve hitch 129 w/ lights 5 mower decks, 2 plow blades, 1snowblower ![]() ![]() ![]() ![]() |
If it was still wet and slipped, it should have gotten warm enough to dry the water in it.
I've never seen water make a clutch slip. They are basically the same as a brake. A little friction and they dry right out. |
![]() Yeah sorry trans clutch. When i went to take a ride up to neighbors about 2 hrs after washing it, it took right off in 2nd but when i got out on road and put it up into 3rd it didnt want to go. Never had prob before washing it. I have never seen water make a clutch slip either and clutch was still engaged with rear in gear so shouldnt have been much get between clutch and pressure plate? Takes right off 1,2 and reverse. A little "grabby" but tgat is normal. Also just took shaft loose from engine and slid engine forward to slip belt in for hydro pump. Will look better tomorrow
John |
Is there a way to adjust spring?
John |
Just a thought, but in the process of "blasting all the grease off" could you have inadvertently put some oil or grease on the clutch disk itself? Seems unlikely, but...
![]() Quote:
More than likely, something is worn, broken or out of adjustment. Pics would help. OP: The chassis manual tells you how to adjust your clutch. |
