Old 01-04-2015, 06:02 PM
CubOCD CubOCD is offline
Default No blaster and sick of wire wheels.
Do you guys think I could use that Aircraft automotive paint stripper stuff? I am just tired of the wire wheels taking forever and I can't take anything to be sandblasted. Has anyone had any experience with it?
Cub newbie! Model 108
Old 01-04-2015, 06:04 PM
Why can't you take it to a sandblaster?
Old 01-04-2015, 06:27 PM
Honestly, the wife would flip out if I put anything like that in our new van. Plus I am nearly done. I just want to get the rest down to bare metal asap as I am impatient lol
Here are some pics
Old 01-04-2015, 06:30 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
aircraft stripper is some nasty stuff,it is actually illegal to use in body shops here.the fumes will choke you and if it gets on your skin,it burns.the other downside is if it isnt completely cleaned off,it will bleed through paint and primer.
Old 01-04-2015, 06:39 PM
bocephus1991's Avatar
The only thing I'd worry about getting down to bare metal is where it's rusty. Feather the edges and prime it. You can use the aircraft stripper and blast it off with a power washer. You need to dry it and prime it ASAP or it will rust. When I painted my 1200 and I'm going to do the same with my 1211 when I do it is use a DA or orbit sander or wire wheel on the bubbled or rusty spots. The rest I scuff it up real good.
Brian
Old 01-04-2015, 07:15 PM
3M Roloc disks. Sanding disks will take the paint right off.... but don't get very heavy ones or you'll be sanding to try and get the deep scratches out. Or use the rubber ones. They take longer, but work. They are way more expensive. If you don't have a die grinder, you'll need one. That's what they attach to. You don't want to use a drill, doesn't spin fast enough.
Old 01-04-2015, 07:30 PM
ford4150's Avatar
ford4150 ford4150 is offline
I've used this on some smaller parts with success. It will take several applications. Just brush it on and wait. Hose or pressure wash off. Available at Walmart, Lowes, Home Depot.
