Old 12-27-2014, 04:39 PM
rdehli rdehli is offline
Default Rear wheel ballast 1812
has any one added washer fluid to there 1811-1812 if so how much in each wheel,
I am thinking of adding liquid ballast to my 1812 for plowing. I'm curious of the pros and cons, and how you guys did it. thanks
Old 12-27-2014, 04:44 PM
I have CaCl2 in the tires on my 1811. About 7 gal per tire IIRC.
Old 12-27-2014, 05:39 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I did my 1864. Here is the thread. I think all methods are covered by others that commented.
http://www.onlycubcadets.net/forum/s...ad.php?t=25622
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-27-2014, 06:13 PM
kh2072 kh2072 is offline
I had a hard time breaking my tires down so I used the washer pump on my truck. Removed cores for valve stem, clamped a piece of fuel line over valve stem, unplugged washer line from the tee going to washer nozzles on truck. Put the washer line inside fuel line and just used the pump and washer bottle on the truck. About 20 min to do both wheels and all I had to buy was a few feet of fuel line and one clamp.
Old 12-27-2014, 06:30 PM
Shrewcub's Avatar
That's pretty creative! Hopefully you won't be replacing your washer pump next week.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 12-27-2014, 06:46 PM
That was a couple of years ago on a 24 year old Toyota with no problems.
