Dad and I got tired of the slop in the front end and wanted a better fix. So we decided to use a wide frame front axle. The wider tires out back will compensate for the wider front axle. Has anyone else done this?
Mark ![]() 1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights 1967 Model 102- mower 1965 model 70 - weights,rear lift and spring assist Model 100 resto mod project, rear PTO, hydraulic lift QA42 snow thrower 42in front blade Grandpa's F-12 and Super M |
I put a 1X8/9 front axle under one of my 122's.
If you use the correct wheels (for the axle) it ends up being the same width as the original N/F axle/wheels/tires. Depending on this tractors intended use, wide rear tires and N/F front wheels and tires looks kinda cool too though.
I did the same on my 105. I used wider wheel in back so the front wouldn't look odd. I also upgraded to 1250 lbs trailer hubs .
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀. |
Can you turn the front wheels "in"??
Yes,Turn your front wheels around or use narrow front rims.
Cub Cadet 100 "Super" (red) show tractor Cub Cadet 100 show tractor. Cub Cadet 100 worker Cub Cadet 106 refurbished/modified (red/white) Cub Cadet 128 "refurbished" Cub Cadet 1450 my dedicated mowing tractor Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper. 100 w/pan seat and 3 point hitch |
Even with a 1" axle?
