I'm working on maintaining my two hydrostatic Cub Cadets, 1450 and 149. It's time to change the hydrostatic fluid, and I was wondering what type of fluid you guys used. Do you use the IH Hy-Tran or some equivalent. Also, when you change the filter and fluid, do you have to pop off the rear differential cover or not? When I got my first 1450 it didn't need anything but a topping up, and I didn't use it a lot because I was working on it and didn't know it's usefulness. Now it's time, so I need to figure it out.
Hytran Ultra, its the only stuff that absorbs water and keeps it from damaging the tranny. Yes, pull the cover , get a new gasket...It will enable you to clean all the gunk that might be in there .
Quietlines and narrow frames, mostly projects but I mow with a 1200 and have a 122 set up for pulls. Wandering the country bringing towers to wind farms everywhere, and bringing yellow stuff home to Texas. Also into flatfender jeeps. |
Ditto what truckntran said
Thanks guys, that was everything I needed to know. Hopefully, I can get the parts I need this next week.
Thanks |
Why is it when you have a Sunstrand in a Cub you must use International Trans and when you have the same trans unit in a JD you must use JD oil? I think if you look closely all the dealers get there oil from the same place. Check the MSDS for the product and it will give you the supplier.
Hytran has moisture absorption properties that the other fluids do not. I have had several rearends that I drained WATER out of because they sat outside, yet because there was Hytran clinging to all of the parts inside, there was no rust at all. I have not seen any other fluid do that.
