First of all I'm afraid I misled you folks and myself on the condition of my tractor
Chris |
Glad to hear you are finding some problem areas. My couplers looked like that on one of mine when i first got it.
Yeah the originals were really poorly made. I had a 1450 that had the same problem. I intended on selling it so I did nothing about it. Of course I had no idea about the vibration issues at that time.
If one cub cadet is good, Two or more would be heaven. |
I'm not getting my hopes too high yet. The parts are suppose to be here toward the end of the week. Hopefully by the first of next week I'll know if I did any good or not.
Keeping my fingers crossed!
Chris |
Just got through totally rebuilding my 1450. Replaced my ISO mounts with some solid mounts I bought off of Epay. Shook so bad that I could hardly hold onto the steering wheel. Pulled the engine out and put in the RUBBER (mind you, not eurathane) ISO mounts in again. Do not crank them down Jethro, as they need to be able to move around a little. Difference between night and day. Now then, I did put in new rag joints as mine were worn. Paid $12.50 a piece for them from the dealer. Take it from someone who has tried to make his own rag joints (they will NOT balance right). The good thing about the OEM joints is that they went right in (and balanced). Another thing to look at is the brass bearing in the engine coupling. When you put the driveline in that coupling, it must be TIGHT. If it slops around, it will eat up your rag joints. Take off the driveline inspection plate between the seat and steering wheel tower. Watch the driveline. At operating RPM you should not be able to see the driveline vibrate. Alright, maybe just a little bit----but that's all! After doing these things, let me know if the vibration is still there. Can't stress enough that you cannot torque down those ISO mounts------that motor has to be able to move!!!
Another thing I forgot to mention is, when putting your rag joints back in, do not over tighten them. A lot of people do. They have lock washers for a reason. If you over-tighten them, it distorts the joint. This will also lead to vibration. Good luck!!
