Are there interchangeable parts for these guys?? I am looking at the rear end in particular.. It is a long crazy thing here.. I am really hopping that it wont be to much to be asking..
Are the axel and hydro of the 129 compatible with the 1250.. The fronts are diff. I know this, so I cant engine swap. I cant afford the Hy-tran, filter and gaskets for the 1250 quite yet.. it looks like they could swipe out with out to much trouble.. And that is just nuts and bolts.. I can do that.. For all who are dying to know.. the guts of my valve feel in the 1250's hydro.. I don't know when it did.. All I know is that it wouldn't go in revers.. So I need to take it apart.. thus,, mentioned above.. can the back ends be swapped?? ![]()
I am broke, but I make it work! ![]() |
Are they both the equal machines? In other words, are they both manual lift, both hydraulic lift, or are they opposite?
both manual..
The hydro's are the same then.
Do they both have the same brake set up? Or is one internal and one external? |
They are both external.
Then the rears will swap also. You can change either the parts, or the unit as a whole.
