When I took the S/G apart to clean and replace brushes, I saw that the back plate was cracked
Patience is the key to success ![]() ![]() ![]() |
Hope it works but I would have had that TIG welded.
TIG weld would work but I've seen cast aluminum crack along side the weld, so I 'll try this. I got this S/G for free for the 125 I'm rebuilding and it was in deplorable condition, almost junk. This is more or less an experiment.
![]() Quote:
![]() Any bending or misalignment of the bonded joint, and you will be back where you started, hence, the sam mac recommendation of welding. Actually, the stick product they sell at gun shows and flea markets that can be applied with a torch (propane, mapp, etc,,,,) does a pretty good job,,, ![]() This would be a better application than their demonstration of sealing a hole in a beer can. How do you get a hole on a beer can, anyways!!?? ![]() ![]() |
Can opener
If you have friends like I do they poke a small hole just above the beer in the can with a pocket knife then stand back and watch it squirt out all over my chest when I take a drink...God I hate that!!!!
"We don’t stop playing because we grow old, we grow old because we stop playing." ![]() |
![]() Quote:
Might want to take the 1/8" plate off, rough up the surfaces and reinstall using that Q-Bond stuff. Really slather it on and fill the edges with it.
But like you said it is an experiment. Results would never be known if you do not try it, right? |
