Hi, I would like to know what the vacant spot on my 782 is on the dash, it's to the left of the hydro control lever. The hydraulic lever is to left of steering wheel, is the vacant spot for front hydraulics? Thanks!
-Rick IH 782 IH 126 CCC 1863 |
It's for the hydrostat control lever "speed stop". A little plastic "bumper" that you can set so that when doing a job, like mowing, you always move the lever to the same spot. Nice for when training your son/daughter/wife/etc.
Ok thanks, really like the 782 and mine does not have that option, interested in another that has this option on the control. I use mine solely for tilling and it exceeds my expectations. The guy I got the tiller from was a retired IH dealer and said you could put front hydraulics on it, wasn't sure if that was what it was for, I see the knock out plugs on the front. I got a front weight bracket but it doesn't fit the mule drive, guess it's for the CCC 1800s
No, no....
Yours has that option. It just doesn't have the part. They all came with it, PO must have lost it. Yes, you can put front hydraulic remotes on it. You can scour e-bay for a valve. They come up from time to time. Oh, you'll need the control handles too and the lines. The front weight bracket will fit. It doesn't go on over the mule drive. You have to take the mule drive off to put the weight bracket on. Kinda like you can't have a blade and the mower deck on at the same time. |
J-mech, thanks. I'll have to take a picture of what I've got. I would love to fit the bracket on my 782 while tilling. Not so much needed while tilling just for a cool factor but definitely needed when plowing. I haven't seen of it will attach to the 124 but doubt it. I did not see where it would attach to the 782 without the mule drive attached without modification. I am still very new to these machines but love them. Learned a lot over the past year or so since owning them
Weight brackets are over-rated. You don't need it when plowing. Really more for looks. Now, if you have a Cat 0 3pt..... then you need one. You don't want any more weight on the front axle than you have to. Now, when the front end comes off the ground is when you need to add weight. I don't know if your bracket is correct or not. Just know that the correct one attaches where the mule drive does. Now, you do need rear weight when plowing.
Here is that control lever stop. It's no big deal. IMG_20140903_210353.jpg |
