I'm looking around at lights for the cab on my 1864 to keep me lit up this winter after dark. My ideal setup that I'm shooting for is to use the two 35 watt lights that come on the machine when I'm going down the road (I have about a 1/3 mile drive to work and between various houses that I do). When I get to a job site, I want to switch off the front lights, and then have 2 flood lights up top of my cab that I can switch on when I start plowing and one in back so I can see where I'm backing up. As far as wiring goes, that's going to be the easy part. I am making a small switch panel with a 15 amp in-line fuse that'll have 4 switches total (I'll use 2 switches for lights, front and rear, and that'll leave 2 for whatever else I may want to add on). I'm thinking some lower power LED flood lights would be a good solution for this setup. So far, I'm leaning towards these:
http://www.amazon.com/LENBO-White-Wa...pr_product_top But I'm curious; what does the rest of OCC use for after dark lighting on there machines? Any suggestions from those that have been down this road?
-Ryan
IMHO, LED's have a poor level of light output. They state they deliver lumens, but, my experience with them has shown different results.
I installed an LED in my shed, along side a halogen that is rated at half as many lumens. The halogen far out performs the LED. I have purchased several of those eBay 12 volt specials, and have tried them, they are all in the junk box. I know we have to scrimp on amps, but, LED's do not seem to deliver.
I use the same lights that came out on the machine. 35W lights in rubber mounts. Very happy. It pushes the amp load to the max, but I have had not issues. I'm running 6 total 35W lights. I do however, let the machine idle (at about 1500 RPM) with all lights off for about 15 min prior to shutting it off. I do this because I found that if I don't, there isn't enough amps left to charge the battery, and after a few starts it tends to go dead. This only happens in winter months when I am pushing snow only in the dark, so the lights are always on. If I stop to come in and warm up, I just leave it running (lights off). As cold as it is, it's easier on the motor to do this anyway. Nightlight.jpg |
LED lights have come a long way in the past 5 years. There are some now that are quite bright. I replaced 50W halogen spreader lights on my boat with 18W LEDs, and the LEDs are much brighter. I've also purchased some "60Watt" equal CREE LED lamps for household use--put three in a ceiling fan. They are every bit as bright as the 60W bulbs they replaced. Now, the $9 ea. price tag is hard to swallow, but they are supposed to last 30 years.
To the OP--if you are looking for bright lights for working at night, I'd look at the marine spreader lights. You can find cheap ones on ebay that might work OK for a while, but folks I know that bought them, discovered they are neither waterproof nor "marine grade." Good quality LED spreader lights might cost $100 each or more. coastalnightlights.com is one well regarded seller. http://www.coastalnightlights.com/st...spreaders.html
sawdustdad: Thanks for the info/link! I know you get what you pay for and right now, to put it bluntly, I'm not willing to pay $40+ per light. Someday the cost will come down, but for now, it's looking more and more like I'll have to go with some classic power hungry lights for my needs. I'm still going to keep my eyes peeled, though!
-Ryan
stock headlights. i used to have a set of tractor style rubber body lights on mine but they looked awful so i took them off, currently have them mounted on my gator but they are going to be removed and mounted to the bumper of my plow truck so i can see what im backing into....smashed the fender of my trailer with the bumper because i had no reverse lamps.
i have no issues with the headlights on my tractors. for some odd reason the 782 headlamps seem to outshine the 2072 headlamps. ive swapped them and still same effect... not quite sure why but i don't hardly use them in the dark anyway.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169. Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3. |
