Old 08-24-2014, 10:36 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Default Question....
I was wondering if anyone knew how long the lift arms are on a factory 3 point hitch? Or the optimal length on any 3 point?
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 08-24-2014, 10:48 PM
Which model?
are you inquiring about the brinly sleeve hitch?
Old 08-24-2014, 10:52 PM
red56turbo's Avatar
Cat O three point hitch????
Josh
Diesel Cub Cadets...........
Old 08-25-2014, 10:38 AM
EarlJ's Avatar
Yes çat 0 I saw a setup built allowing the use of the Brinley set up still. His lift arms look to be too long. It's a pretty neat set up because it uses the upper portion of the rear lift via the pin hole.
Old 08-25-2014, 10:53 AM
bolivier's Avatar
bolivier bolivier is offline
I saw that on facebook too. Cool idea, but I think it needs some tweaking. For one when finished it was sitting on the ground. I can tell by looking at it that it's not going to lift high enough to do anything. I think his arms look really long because on a normal cat 0 the arms go under the tractor a little bit, where his only go the back of the rear end. I think he was onto a good idea, but all the kinks are not worked out yet. I'll go out it a minute and measure my lower arms if nobody beats me to it.
Old 08-25-2014, 11:01 AM
bolivier's Avatar
My lower arms are 21" long. This is on a factory 3 point on my 2082.
