Old 08-05-2014, 09:08 PM
williebgood75 williebgood75 is offline
Default Got the 127 running again
What an ordeal, first go around. In less than an hour, I wiped out the new rod. std. I found a shop & it would not clean up at twenty, they welded it an turned it to standard bore. It seems to have a little side clearance on the crank. I mowed at two thirds throttle for 2 hrs. 3 more runs, and change the Oil.
Old 08-05-2014, 10:18 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Congrats on getting the 127 going again! I feel like I'm reading a telegram...It's free to post here!
Plow blade
#2 Cart
QA36 snowthower
Old 08-05-2014, 10:27 PM
Old 08-05-2014, 10:28 PM
Kohler cranks can't be welded up. They will break. You may be doing this again. I don't know where you found a shop to weld it. My crank grinder refuses, no matter what.
Old 08-05-2014, 10:38 PM
TheSaturnV's Avatar
I know its a "new" engine, but mow at W.O.T.
stop.
Old 08-05-2014, 10:53 PM
stop.
I wouldn't recommend that on break in. He did it right.
Old 08-06-2014, 09:05 AM
TheSaturnV's Avatar
Left out a few words there.
AFTER break in, mow at WOT.
