I went and picked up an Original. I'm new to the Originals. It seems like its in decent shape for a 1962. Everything seems like its original and unmolested from what I can tell. Again I am new to these. It runs and drives nice. The engine does smoke a tiny bit but runs smooth and has good power. I was told it has been sitting in a garage for years. The only real issue I see is the fuel line from the sediment bowl to the carburator leaks. It's a hard line with fittings on the ends that use a piece of rubber tube inside to seal. Does anyone know where I can get the replacement seals and what size they are? Also the throttle lever doesn't want to stay at full throttle, it creeps back to idol. I have to look to see how I can tighten it up. I will be cleaning it up and checking things out this morning. I will also change the oil today. What type of oil and how much is needed for the rear axle? Pictures will be posted shortly. Thanks.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart 882- 50c Mower Deck 2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade Case 646 FEL Case 446 |
last time i needed to replace those seals i simply found the proper size fuel line and cut a couple small pieces off
I run 80w90 in my cubs without issue.
Thanks. I should have asked before, any idea how much oil I need?
Nice find.
Not off hand, check the manual
The owners manual calls for Hy-Tran or 30W engine oil. For what it's worth I run 30W in my O and my 71.
