Old 06-24-2014, 11:19 AM
Default 1200 Mowing Speed
Howdy folks. I just read through a post where a new 106 owner was asking about reducing gear ratios, and there were some good answers there. In my case, being used to mowing with hydros (except for my ford tractor and a bushhog), I noticed that even in first gear at WOT, it seems a little fast. I can see the beauty of having good sharp blades if your mowing that fast. I dont have the creeper attachment. Is the creeper attachment the best option for going slower? Reducing the throttle doesnt seem like a good answer, our grass is pretty demanding when it gets thick! I just need to slow down a little to mow the thicker growth. I guess I could just jump on one of the hydros, but this new 1200 is too much fun! Thanks, TB
Old 06-24-2014, 11:22 AM
Mow more often.
Old 06-24-2014, 11:40 AM
jimbob200521's Avatar
Mow more often.
What that guy said!
Edit: Or mow a little higher?
-Ryan
Old 06-24-2014, 12:20 PM
Or get a creeper gear.
Up to 530 and counting...
Old 06-24-2014, 12:22 PM
Mow more often.
Thats not always an option, here in PA we're getting one thunderstorm after another so im only getting to mow every 7 or 8 days and my grass is over a foot tall in that time.
Old 06-24-2014, 12:25 PM
Thats not always an option, here in pa we're getting one thunderstorm after another so im only getting to mow every 7 or 8 days and my grass is over a foot tall in that time.
Then mow higher, and then mow it again. This really is not a gearing or tractor problem guys. It's a use your head kinda thing.....
Old 06-24-2014, 12:28 PM
but a creeper wouldn't hurt,not like using your head to cut grass...
Old 06-24-2014, 12:39 PM
That is true.....
Old 06-24-2014, 10:57 PM
db4570 db4570 is offline
I'm that guy. I'm thinking about buying one of the 20% underdrive reduction gears from Brian Miller at tractorpullingtips. But it would be much better if you did it first and reported back how difficult it was to install, and how well it worked.
Seriously, it sounds like a 20% reduction might be just the ticket.
David
Old 06-24-2014, 11:06 PM
David
Buy a creeper!
Go ahead and buy a reduction drive. I'll be laughing it up when you guys are taking your trannies back apart to put the original gears in because now it's too slow, and you can't shift gears. At least with a creeper, you can shift back into direct drive.
I'm done. Have at boys!
