I want to build a Brinly-type hitch adapter for my narrow frame Cubs. I found design plans from Steve Spencer on the hitch and receive the lift strap dimensions from Charlie Proctor. I question Steve’s dimension for the width as he has 9.50 – using .38 inch steel that would mean that the lower hitch bracket on the tractor itself would have to be smaller than 8.75 – I measured mine at around 9.06 to 9.10. I made a drawing using some of Steve’s design (okay, most of Steve’s design) and Charlie’s lift strap measurements. I changed the 9.50 dimension from Steve’s to 9.88 (I’m thinking about increasing this also).
Unfortunately my design plan is in the pdf format and is 111KB, so I can’t attach them here (too big). I want to get some feedback, and this might benefit anyone else who wants to build one. So…… http://cubcadet.1.forumer.com/index....pe=post&id=442 |
nicely done I was going to build one for my 782, is it nescisary to have the inside mount on the rear diff cover where the the pivot mounts to? i guess i could see it being a better stonger set up than just the single hole org factory set up
No, but it's a good idea. The double bracket lets you use clevis pins to attach the sleeve hitch adapter to the 3-point without destroying the holes in the lower 3-point bracket and adapter. With the single lower bracket, I'd advise using a rod all the way through both sides, and not using clevis pins, as the pins will cause wear in the hitch and adapter if it is just a single bracket.
Here is will happen to youe sleeve hitch adapter if you don't use a double yoke:
![]() The shiney area was welded to build egg shape hole back up. The holes had that much wear in them from a single yoke system. Aother problem with a single yoke set up is you will have side play in you implement. I did some research awhile back in the Cub Cadet parts lookup. The IH tiller, box blade and rear blade had support on both sides of the implement's arm. IH engineers saw the problem and had a solution for their products. I'm not a big fan of using a a rod all the way through both sides as Matt suggested. The rod can and will bend. This is the set up I use: ![]() |
The doubling of the lower hitch gives me an idea - tomorrow I will try and put a Rev "A" to my plans to include an extra "arm" on both sides to mimick what Merk has shown. Only it will bring the doubling effect to the hitch adapter, not to the tractor side.
