Any ideas why my 1772 runs about 20 degrees cooler (130) than my 1572 (150). I checked the thermostats both are in and working. I used a laser thermometer and checked all around engine, Thermostat housing and radiator and all are about 20 degrees cooler. I also put a thermometer in radiater with same results.
Charles________________________ 1572 3pnt, rear PTO, 50" deck 1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow 1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow 2072 3pnt 50" deck, Brinly Plow 2072 50" deck Cub Cadet Tank 50 Zero Turn Cub Cadet 33" Commercial Walk Behind 1953 Ih Cub with just about every implement New Holland TC33D with Loader and Backhoe |
Nice set of supers! What's the model of your other super? Sorry, I can't help on the temp question.
I'd say calcium and rust buildup inside the cooling system. May even be a difference in the radiator build. If the tractors are only running at 130 and 150 it's nothing to worry about anyway. AFAIC, that's a little cool. I like to see water temps of 175-200 (working temp). Too cool a cylinder will wear funny.
The other super is a 1872. Still looking for a 2072
Cool deal, I really like my 1872!
Maybe the radiator in the 1772 is in a little better shape than the 1572. My 1572 ran a little on the hot side. I installed a new thermostat and there was no change in temp. I used a radiator flush and refilled. I also added a little Water Wetter to the radiator and that brought the temp guage down considerably.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
What is water wetter?
What's the best way to flush the radiator?
its an antifreeze additive that suppose to lower the coolant temp by a few degrees
http://www.summitracing.com/parts/re...FSqXOgod2FIAPA
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
