Since my 2182 is down right now, I mowed with the 1450. I am amazed at the difference in the fuel consumption between the two.
I mowed about 2.5 acres with right at 1 gallon of gas. That same amount would have taken at least 2 gallons with the 2182. Might have to make it a regular thing!
CC 2182 w/ Cat. 0 3pt. lift 54"GT deck IH CC 1450 w/ CC #2 tiller and 44" deck |
Wish I was cutting grass w'ere going to be plowing snow Wednesday
102 ,129 ,149 ,169 ,154, tiller .chipper wide frames rule |
I had the exact opposite experience with my 1450, it's a fuel hog! Then again I'm comparing it to cutting grass with my O.
![]() Bill |
Had similar results this winter, when the thrower was on the 1811 or 682, I'd have to fill up after a couple hour full throttle blowing session. When it was on the 129 I had (with a 14hp Kohler) I'd still have to fill up every couple hour blowing session but then again, you're looking at a 1(ish) gallon tank vs a 4 gallon tank
-Ryan
I've heard that all vehicle manufacturers use a formula to figure out what size tank to install so the car or truck could travel close to a 400 mile trip before refueling. I wonder if that is true for other machines in hours such as tractors and mowers.
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
If a hydro 1450 seems fuel stingy, try a gear drive,,
![]() I can plow snow for an hour with a quart of gas. ![]() The hydro is wasting at least 20% of the HP, and gasoline. ![]() |
My 100 was a lot better on gas, than my 782 and 1872. Course the 782 and 1872 have twins in them versus the single in the 100.
