Deep into the process of rebuilding my 1250 with K301. Bought a used crankshaft, good fit, EXCEPT: Starting to put my PTO clutch back on and it is does not have the threaded whole in the end of the crank. It apparently came from a Cadet that used the set bolt to make contact with the Key.
Question: Can the Crank end be drilled and tapped while in the engine, or can I use one of the clamp on PTO clutches on the 1250? Or, does it all have to come back apart?? |
Here is a vid of a guy drilling a crank in the engine:http://m.youtube.com/watch?v=fO1JUnP7ZTo
thanks for the video. Maybe should talk to the machinist who. bored the engine to see if he can tackle it. He might have a something like that.
The machine shop should have no trouble drilling and tapping the end of the crankshaft for you.
actually if you own a drill and a tap and die set it isn't that hard if you can drill a straight hole. the cranks are cast iron so its easy to work with. you might want to measure the length. I thought there was a slight difference in length on the pto end. but I could be wrong. been a while
![]() Quote:
