Old 01-14-2014, 07:51 PM
Juicybusa Juicybusa is offline
Default 127 Amp Gauge
127 amp gauge constantly fluctuates in the positive range at anything above idle. I'm not accustomed to seeing this level of needle fluctuation since my O does't have one. Voltage reads 14.5 at the battery fast idle. Gauge? Regulator? Or normal?
Old 02-24-2014, 09:44 PM
mattoney mattoney is offline
I just got the charging system on my 107 running tonight and have had the exact same issue. It'll bounce all over the charge side for awhile until I slow down to idle. Then it goes all the way to discharge for about a second and then centers out to 0 until I speed it up again.
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree.
Old 02-24-2014, 11:22 PM
I think I've narrowed this down to regulator vibration. Don't know if I am missing some dampening rubber on the regulator mounting or not or if possibly the cubs require something unique about their regulators to tolerate the vibration. Any further insight appreciated.
Old 02-25-2014, 12:32 PM
gophred's Avatar
gophred gophred is offline
I think you are on the right track. I had that on a 129 I bought which had totally dead battery. The owner started it, but only with a 100 amp charger and the V.R read zero so I was not confident about the charging/regulating. When I got home with a good battery the regulator was flying all over. I put a spare V.R. in and it read much steadier and positive. could be the adjustments letting the vibration open/close things when they should not be?
Gophred
2 - 1811's with 50C decks, one mows the other is waiting on deck, 129 (my sons retromod)-, hydro lift, custom 3 pt with a trailer ball , foot pedal speed control, used for trailer hauling. 129 (mower) 42" deck, foot control, 1810 with 44C - next in the slow death march of mowing the camp. a few 1200 series parts rigs. 2017 Kubota b2650 loader mid mower.
Old 02-25-2014, 01:24 PM
Totally agree!
Old 02-25-2014, 06:22 PM
dagenham dagenham is offline
My 127 bounces all over the place from discharge to charge at high idle. I'm not sure if my charging system is working correctly or not. The s/g is fresh and the v/r is supposed to be good, but that is questionable to me.
I am with juicy and the dampening rubbers on the v/r. Is there supposed to be some there or not???
