Pretty much like the title says... I've noticed since I got the tractor it's got a STRONG gas smell, took the air cleaner cover off and the pre-cleaner is soaked. I watched and after about 2 minutes there's a drip of gas coming out of the carb. Like a leaky faucet... not a steady drip, but enough that it falls out of the air cleaner cover after a few. Ideas? Suggestions?
Gary '49 Farmall Cub, '62 "Original, '70 73 w/402-D Haban sickle, '71 127 w/38" cast end deck, '73 149, '76 Sof76, '07 LT1045 w/bagger, '09 GT2544 w/bunch of mods. 5 Exmarks, Kubota B2920, blah, blah, blah... |
If it were me, i would order a rebuild kit from one of the sponsors and totally go through it with new seals, gaskets and such... and shut off your gas at the float bowl when you arent using the tractor.
1981 IH Built 782- 44" deck 1650 dual stick 71 "121" round fender and replacement k301 carlisle tru powers and v61 |
Do as sgirdham says.
Your problem with that tractor is a leaking needle/seat. (Also, make certain to correctly set your float height during the carburetor rebuild.) Best of luck.
Cub Cadet 129 48" deck - grass mowing 38" deck - backup deck 42" front blade |
The needle valve is not seating properly with the seat.
Check for dirt, bad float, stuck float, bad needle, bad seat or any combination.
![]() Quote:
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
Gary,
Sounds like a carb rebuild is in order. I always shut the gas off at the tank as well. Even if the carb doesn't leak. Just a habit I guess.
Josh Diesel Cub Cadets........... |
Here's the thing... it doesn't have a fuel shutoff or sediment bowl... I always thought those were standard???
DSCF9937 (Large).jpg DSCF9938 (Large).jpg DSCF9939 (Large).jpg DSCF9940 (Large).jpg
The shut off is right there under the tank, but the handle is broke off.
No bowl on these, but there is a screen (or should be) on the shut off.
Well along with the carb rebuild I would drain the gas and install a shutoff. Might wanna take the tank off and clean it to.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
Hopefully I can get started on it this weekend. I don't mind the gas smell, as the garage has smelled like a mix of hy-tran, diesel, gas for years now! But apparently the wife doesn't like getting the buzz from it! haha.
