Old 08-19-2013, 03:19 PM
mike melillo mike melillo is offline
Default Engine drive plate hub mount position
Dose anyone know if the hub slot wears more slowly if mounted in a specific position with respect to TDC? There are 2 mounting position options and the thought crossed my mind.
I looked at the 149 manual and it doesn't specify either. In the years past I never really considered this, but it dose wear faster than I would like.
Mike
Old 08-19-2013, 03:30 PM
I have absolutely no idea what you are talking about. What hub? The one on the rear? I can't think of anything that can be bolted on two ways..... How about some more info. And maybe some pics. You mentioned a 149, so a K321 right?
Old 08-19-2013, 05:00 PM
I'm not saying that it isn't possible, but in all these years, I have never heard of anyone mounting the adapter a certain way to make it wear slower.
It would be nice if it were true though.
Old 08-19-2013, 06:18 PM
I kind of figurer that its a long shot, but the aluminum pulley is pinned to the flywheel, and the tapped holes within are cast in the same location on the few I have hanging around. With that and my thought that IH/Kohler didn't just guess at the place to cast those hole makes me wonder. Plus after combustion, and as the mix is compressed the loads on the crank change, and could be transferred into the hub affecting the wear pattern. I really don't know, but I thought it was worth considering.
Mike
Old 08-19-2013, 10:47 PM
Juicybusa Juicybusa is offline
Dang Mike, I guess I'm not the only one that thinks like that ! Good question.
Old 08-19-2013, 11:26 PM
The hub is a circle guys. It doesn't matter. It would wear the same no matter what. It's like a flywheel and clutch. You can bolt it on 6 different ways, but the wear pattern would never change.
Old 08-20-2013, 03:28 AM
Mike
I don't disagree with what your theory, at some point there has got to be a difference. I was thinking more along the lines of a vibration factor.
However, I believe that the alignment of the engine in relation to the drive shaft along with maintaining a smooth running engine, is probably about the best friend you are going to find concerning the wear issue on the adapter, drive shaft and pin.
All in all, getting 40 or 50 years of service out of one of these little machines is still pretty impressive.
